12-27-2024 05:53 AM
Hello.
I am working on Cisco DN3-HW-APL Server.
After setting up as Standalone, via the maglev-config wizard step.
The enterprise IP address, i configured 10.60.x.x was reachable via ping and i can access the DNA center via web.
I shutdown the server for the holiday and decided to input management route, But i keep getting error message to fix network setting.
I have rebooted and tried again, still can't go beyond this page or access the "enterprise" interface via ping or web.
12-27-2024 06:00 AM - edited 12-27-2024 06:01 AM
It means the enterprise interface is not able to reach the gateway or the DNS that you have configured, make sure they are reachable.
12-27-2024 06:10 AM
This are my information on Cisco Catalyst center
IP address: 10.60.4.100
Subnet: 255.255.254.0
Gateway: 10.60.4.1
DNS: 4.2.2.2 8.8.8.8
config on SWITCH
Twe1/0/5
switchport mode access
seitchport access vlan 10
It worked during the first setup and now it's not validating.
12-27-2024 06:47 AM
Connect a laptop to the switch in vlan 10, make sure from the laptop you can ping gateway and dns.
12-27-2024 06:52 AM - edited 12-27-2024 07:02 AM
Yes. I can ping the gateway and access the internet on my laptop.
while on the catalyst center.
I can learn mac address on the interface with vlan using "sh mac address-table interface twentyFiveGigE 2/0/41".
I used this command "sudo maglev-config update". or "maglev-config wizard". yet it's not reaching the internet or validating.
12-27-2024 07:43 PM
can you try maglev wizard again through KVM and try just one DNS may be 4.2.2.2 or 208.67.222.222, see if you still get the error
12-28-2024 02:50 PM
12-29-2024 05:24 PM
try "ip link set <interface-name> up"
12-31-2024 01:06 AM
I think cisco TAC should be my next step or re-image. Thank you very much
01-06-2025 06:09 AM
It's because you are not out of the restricted shell so you cannot use that command.
Also, please do not use the maglev-config wizard command, that attempts to onboard the appliance as though it was reimaged.
Ens1f0 should be the cluster port, not the enterprise port. Can you provide the following please:
ip a | grep -e en1f -e enterprise -e cluster -e internet -e management
01-07-2025 03:28 AM - edited 01-07-2025 04:16 AM
Thank you for your response
I typed the command but no output, screenshot below.
Here's a snapshot of the interface.
It's surprising that the interface are blinking, and it enterprise interface was reachable the first day i powered on the device but now it's not/
01-07-2025 06:43 AM
Yea, I apologize, it was supposed to be ens1f, I forgot the "s". However, something still should have showed for all the other ones.
ip a | grep ens1f
ifconfig -a ens1f1
ifconfig -a ens1f0
01-07-2025 08:56 AM
Yes, so i used ens1f
ip a | grep -e ens1f -e enterprise -e cluster -e internet -e management
It's says interface is down, i have 10G-SFP-S-SR plugged to the port, blinking orange and green light.
I'm curious what could be the issue and when i tried "ip link set ens1f1 up" or "sudo ip link set ens1f1 up" i get display message "operation not permitted".
01-07-2025 10:49 AM
Yea, the network interface is failing to initialize. We would need to look into the logs. If you opened a TAC case, what is the SR? If you haven't, please do so.
01-14-2025 02:57 AM
I will open TAC in few days, so i can resolve this issue as it's beyond normal issue.
