Cisco DNA center provisioning
nathanmonteyne0
Hi All,
So now I'm getting an error message while provisioning after LAN automation
I get this error message when it's in the 3th step of provisioning "validation of business intent"
NCSO20470: Provisioning failed due to error in retrieval of ISE PAN IP addresses. Fix the DNAC-ISE integration and retry the operation.
I've already looked around on the different forums and I come across bugs. But that should not be possible as I've already provisioned 80+ devices with 0 errors.
There have been no changes in the templates we use, no upgrades of DNA and no upgrades or changes in the ISE.
Can anyone help me in the right direction?
Kind regards,
Preston Chilcote
My guess is that a cert expired either in ISE or DNA.  If you need help troubleshooting that, please open a TAC case.
Syamkumar
Have you found the solution to this? i am having the same issue while provisioning a template to the Switches.
This could be due to integration issues as specified by Preston last year. Can you go to Menu → System → System 360, then navigate down to the Identity Service Engine section and confirm the status of Cisco ISE? (Please provide a screenshot)
You were right, this is the integration issue with ISE initially, Once integrated again with DNAC, we were able to
