DNA-Center reinstall from scratch (.iso image)
Thomas Roeckel
Hello together,
i have to reinstall the DNA-Center from scratch and therefore i need the bootimage. According to the Cisco installation guide you should:
Download the Cisco DNA Center ISO Image
You can download the latest Cisco DNA Center ISO image from Cisco.com
Step 1   Go to the following URL address:
https:/​/​www.cisco.com/​c/​en/​us/​support/​cloud-systems-management/​dna-center/​tsd-products-support-series-home.html
But i can't find the image anywhere. Any ideas?
24 Replies 24
"It doesn't mention anywhere about doing this via virtual media - it just says bootable USB."
That is correct. as I mentioned above, USB Bootable is the only "supported" method.  "Supported" means that we have tested and verified this method and the Cisco TAC will support install failures using this method.
If you use another method, (although it will technically work in most cases), this is not officially supported so if it fails... this is not supported as an official process.
I've had reinstalls from the ISOs take upwards of 20 hours through the CIMC HTLM5 KVM. To be fair though, this was over a WAN link, so the bandwidth and latency were the killer. Key being it worked fine but just had to wait.
This is a lab.  There is no real traffic so it worked perfectly over the KVM link and the client and server were on a different VLAN (Layer-3 adjacent).  Took just less than 4-hours to be back where It needed to be.
Andy
Less than 4 hours all service download and up and running is a good specification of your compute and good link speed towards cisco download.
BB
Lol.  4-hours?  An acceptable amount of downtime? I think not....
Single box it is just an orchestration tool should be ok I guess - that is only first-time installation.
Cisco suggests 3 node deployment - for real production.
BB
hbernal01
I am currently trying to do a re-image with all the steps provided by the Cisco guide but after an hour of installation I get the following error
Any idea why it is generating and how to fix it?
PabMar
It may take you a while to do, but try the following:
1. Perform 2x Fast Init on all 3 virtual drives using the CIMC GUI.
2. Reboot the appliance, do Ctrl+R on the RAID tool, perform Fast Init on all 3 virtual drives.
3. Download a new ISO to make sure it's not corrupted and burn it to the USB.
4. Run the fresh install again.
Hope that gets you through.
Regards.
i created baleno ethcher to create usb drive using windows 10. but after successful creation when i plugged to laptop it tells to format it again. it only shows its connected nothing else. so what format the usb created. can anybody tells about it? how can i verify from windows ? is this really created?
Any specific reason  why you are doing the Fast Init 3 times?
Seems a bit weird that the image loaded from the USB end up pretty similar to the normal install. With the exception of the Grub Menu.
