Dna Criteria for Enabling Application Telemetry on Devices
dijix1990
Anybody knows how does change criteria for Enabling telemetry in DNA? I mean change default parameter - Interface description has the keyword lan
It's so inconvenient and strange, I noticed that dna applyes ipdt config for all access ports on legacy switches (2960+/2960x) but not for c9200/c9300 if they doesn't have keyword lan on the description
dijix1990
I want to do that, because Automatic Selection Algorithm doesn't work properly in DNA. I apllyed "telemetry enable", but dna did the changes only for interfaces with "lan" and by the way, I found that it has some bugs, maybe it is bug too
what DNA version are you running,. i am sure of you configured netconf, which automatically sends information to DNAC.
BB
