DNAC Aura Reports
ducetcro
I feel like I'm taking crazy pills, did something change in dnac 2.3.3.7 to remove how aura reports work? I used to just have a ./dnac_aura folder but it disappeared from every node(I cannot find anything related to aura) and i am fairly sure i was able to use git clone before to pull it down/update it but now the cli does not recognize the command. Im SSHed in as magctl. Did something change and if so how do you run aura reports now?
Torbjørn
In 2.3.3.X you are enter the restricted shell by default. Hence you probably need to enter unrestricted shell with "_shell" or "_shell -c 'sudo magctl ssh shell bash'", note that this is unavailable from 2.3.5.X onwards. See the README.md for Aura for more details: https://github.com/CiscoDevNet/DNAC-AURA/blob/master/README.md
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Preston Chilcote
