Error during Cisco DNAC installation
wsoonhin
I am trying to install DNAC but encountered the below error during the initial configuration:
What could be the possible cause?
=== stderr ===
Can't open file /etc/maglev/.pki/passphrase.txt
Error getting password
140580132876736:error:02001002:system library:fopen:No such file or directory:../crypto/bio/bss_file.c:72:fopen('/etc/maglev/.pki/passphrase.txt','r')
140580132876736:error:2006D080:BIO routines:BIO_new_file:no such file:../crypto/bio/bss_file.c:79:
| 2021-10-18 07:54:49,174 | ERROR | 12396 | MainThread | 139826393159488 | root | config.py:819 | Pre-Install: Error while configuring appliance |
Traceback (most recent call last):
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/managers/config.py", line 701, in _perform_default_install
responses, error = self._perform_common_install_operations(responses, step_callback, force)
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/managers/config.py", line 665, in _perform_common_install_operations
temp_passphrase_file=temp_passphrase_file,
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/managers/config.py", line 1079, in _generate_certificates
force=force,
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/managers/pki.py", line 92, in generate_signed_certificate_keypair
self._generate_rsa_private_key(private_key_file, cipher="aes256", passphrase_file=passphrase_file, force=force)
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/managers/pki.py", line 146, in _generate_rsa_private_key
ShellCommand.run_command_with_poll(command)
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/common/shell_utils.py", line 125, in run_command_with_poll
raise ShellError(message)
ShellError: Error while running command [openssl genrsa -aes256 -passout file:/etc/maglev/.pki/passphrase.txt -out /etc/maglev/.pki/kube-admin-key.pem 2048]:
=== stderr ===
| 2021-10-18 07:54:49,209 | ERROR | 12396 | MainThread | 139826393159488 | root | config_utils.py:689 | [_perform_default_install:820] Error while running command [openssl genrsa -aes256 -passout file:/etc/maglev/.pki/passphrase.txt -out /etc/maglev/.pki/kube-admin-key.pem 2048]:
=== stderr ===
| 2021-10-18 07:54:49,210 | ERROR | 12396 | MainThread | 139826393159488 | root | silent.py:98 | Error while running config wizard |
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/commands/silent.py", line 87, in cli
exit_with_error(0, error)
File "/opt/maglev/local/lib/python2.7/site-packages/maglev_config_wizard/common/utils.py", line 74, in exit_with_error
sys.exit(1)
SystemExit: 1
regards
sh
Tomas de Leon
The problem looks like the exception occurred do to an NTP Sync issue.  Verify that the NTP server is reachable from the IP addresses that you configured on the Cisco DNA Center interfaces.  Also, verify the layer 1 is up for the interfaces that you are configuring.
If you have some of the earlier screenshots showing what you are configuring would be helpful. But the problem appears to be related to your NTP configuration and the syncing to the NTP Server.
Also, make sure NTP is also configured on the CIMC network settings also.
I see. I will try it out first.
support-se
Hello we are having the same problem, any solution for this ?
explain more about your issue, 2021 and 2023 there are many changes done in DNAC installations.
post the error and explain about your environment.
check the installation guide step by step.
BB
