Fail: Upgrade Catalyst Center (DNAC) to 2.3.7.7-70047-CSCwn89323.SMU
ChuckMcF
Quick caution, you may wish to contact Cisco prior to attempting and upgrade to 2.3.7.7-70047-CSCwn89323.SMU. Our recent attempt failed and we opened a TAC case. Apparently, this new upgrade has a few issues and "many customers are experiencing an issue with the upgrade." TAC was able to resolve the issue and we have now successfully completed the upgrade but it took about 36 hours from the start or the process.
I'm fairly certain that they will resolve this issue soon, but I just wanted to make the community aware of the possible issue.
ChuckMcF
8 Replies 8
Thank you for your message about (Release 2.3.7.7-70047-CSCwn89323.SMU) i´m in the download process and before to apply this version i will open a case with TAC Cisco.
Thank you @ChuckMcF for the heads up. Can I ask what version was running on your Catalyst Center before attempting the upgrade?
I'm assuming it was 2.3.7.7-70047.
Regards, LG
*** Please Rate All Helpful Responses ***
Yes, we were running 2.3.7.7, which I guess was technically 2.3.7.7-70047.
ChuckMcF
Torbjørn
Thank you for sharing! Had a few upgrades lined up
EDIT: It is apparently this bug: https://bst.cisco.com/quickview/bug/CSCwn25172
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Done the upgrade to 2.3.7.7-70047-CSCwn89323.SMU yesterday successfully, and thanks for the sharing!
rasmus.elmholt
Level 7
Level 7
Just tried to upgrade the day before yesterday. And the upgrade is hanging on downloading applications( Downloaded (35/49) )
So I guess there is still some issues with the upgrade.
ChuckMcF
Fairly certain that is exactly where it caught me - 35/49. Call TAC, they are aware of the issue and can get you through it fairly soon.
Good luck!
ChuckMcF
MartinKajan
I had a feeling I should have checked the forums before clicking upgrade..
