04-02-2024 01:54 AM
Hey, everyone.
I'm trying to set a SD-ACCESS envionment follow this document.
However I meet this error while set a L3 switch as a control plane.
Failed to add device XXX.a.com to the Fabric Site/Zone. Please configure Loopback0 interface with an IP address.
I checked the switch, it has SSH, SNMPV2 read and write configuration. And it use OSPF.
It will be a great pleasure if anyone can tell me how to solove it.
Thank you so much.
04-02-2024 04:15 AM
Does the switch have a Loopback0 interface with a /32 IP address assigned? If not you will have to configure it.
04-02-2024 04:51 PM - edited 04-02-2024 11:17 PM
Thank you for your reply.
Yeah, I noticed this, and set a /32 IP to the Loopback0 interface. And set it to my ospf x area x network.
The loopback 0 address can be pinged from DNA Center.
And it also failed, show the same error message......
04-03-2024 09:26 PM - edited 04-03-2024 09:27 PM
To be honest I'm not across the ins and outs of Lo0 rules in Catalyst Center / DNA Center. Two things come to mind that you could try in order:
1. After adding Lo0 to the device, did you resynch it in Catalyst Center inventory? If you make a config change on a device then CC will only know about that change after the next resynch which is run periodically to a schedule, or manually triggered in the Inventory screen.
2. In my Catalyst Center I manage the switching devices by their Lo0 /32 IP address. In Inventory you could edit the device to be managed by its Lo0 IP address, resynch the device, and then try to provision the device into an SD-Access Fabric.
