Smart license for cisco 9200
Noovi
Hi Guys,
I have one Cisco 9200 and smart license is not install on it.
I want to know what will be the impact on device if i doesnt install smart license.
License Usage:
License Entitlement Tag Count Status
network-advantage (C9200L-NW-A-48) 1 IN USE
dna-advantage (C9200L-DNA-A-48) 1 IN USE
6 Replies 6
 Operational? none. You are going to receive a lot of logs only. But, if you had some problem and get TAC to look, they might point this.
balaji.bandi
it says already in USE, show License summary or status give you information.
it works as long it was permiitted,
BB
Actually currentlly they are in Use but may be in evaluation.
My query is if they got expired after evaluation, is there any impact on network/operation?
If they are not register in time, it fall back to basic level that essential License.
BB
Afaik that is not correct. If using IOS-XE 17.3.2 and higher, SLUP is in place which does not include any service degradation on switches. Based on the Smart Licensing enable products list*, impact for Catalyst 9200 is "Normal functionality. syslog/alarm notifications."
*https://www.cisco.com/c/dam/en/us/products/collateral/software/smart-accounts/smart-licensing-product-details-external.xlsx
Benjamin-A
Hi Noovi,
check this out please: https://www.cisco.com/c/en/us/products/collateral/software/one-wireless-subscription/nb-06-dna-acces-wl-sw-faq-ctp-en.html
Search for the Question: "Several customers believe that when their subscription expires, a Catalyst 9000 switch will not work. Can you confirm if L2/L3 services will work if the license has expired?"
What features are included within DNA Subscription and which one in Network Essentials/Advantage can be found here:
https://www.cisco.com/c/m/en_us/products/software/dna-subscription-switching/en-sw-sub-matrix-switching.html
Network Essentials / Advantage = permanent
DNA Essentials / Advantage = subscription
.:|:..:|:.Please rate helpful posts.:|:..:|:.
