System update of DNA Center (9800-CL integration)
pcarlier1
Hello all,
My company would like to perform a system update for our DNA center and I was wondering if there are things I should watch out for since we have a 9800-CL (16.12.4a) Non-Fabric deployment using DNAC.
We are upgrading from 2.2.2.4 to 2.2.2.6. The upgrade guide makes it seem like a walk in the park and I can't find any info regarding pitfalls to keep in mind. Seems to easy which in my experience it usually isn't.
Would love some feedback on this. Thank!
usaf_27
The 9800 controller has has nothing to do with how DNAC is updated.  I have done many DNAC system upgrades. I will say they are “that easy” unless you hit a weird bug.  However, since your staying in the same train version, you are safe for the system upgrade.  Version 2.2.2.6 is a bug release only.
usaf_27
Preston Chilcote
If you want to be really thorough, you can run the AURA tool ahead of time:
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/dna-center/215840-cisco-dna-center-aura-audit-and-upgrad.html
Personally, I would probably skip this step when upgrading to a bug fix release, as you are.  I would probably run it when upgarding to 2.2.3.x and definitely run it when upgrading to a new major release like 3.x (whenever that day comes)
