Will DNAC support interface bonding?
a12288
Level 3
Level 3
I understand the DNAC doesn't support LACP, while other UCS-based appliances like ISE do support interface bonding. So does DNAC support interface bonding? I cannot find any document to mention this. Thanks.
Leo
6 Replies 6
Pavan Siripuram
No Support as of now for bonding.
Tyler C
As of 2.2.1.x, LACP NIC bonding is supported.
What CIMC version would be needed ?
Thanks.
Can you point to where it talks about interface bonding in the link you referenced? I don’t see it.
Thanks.
