UCS - VCSA 2.0.4 - integration/upgrade problems
Saaditani
Dears,
I have installed the plug-in 2.0.4 and its working however when I wanted to updated to plugin 2.0.5 it does not show in VCSA 6.5 U2 – Home page.
I have to unregister it and register 2.0.4 to be visible again.
I have VCSA 6.5.0 – Build: 11347054
UCS 4.0.1(B)
On Side note the 2.0.4 only integrates with 1 CISCO Blade and the others gives a popup that I need – re-register:
globallic
thank you! I will try and report back...
But If it worked out, I am obliged to use the HTML5 version (which I am not using it now as I am on 6.5 U2), not fully functional unless upgrade to 6.7
Not compatible.
Cisco UCS X-Series Energy Efficiency Offer
