07-18-2017 12:10 PM
We have a user that configured Proximity and has since left the organization. The new assignee of the phone is complaining about seeing the icon. After a factory reset, this icon remains. Is there a way to remove it?
The icon looks like a little cell phone, NOT the bluetooth icon.
Any help is appreciated!
Solved! Go to Solution.
07-21-2017 12:32 PM
Hi, on CUCM for this specific phone, can you locate the following parameter Allow Bluetooth Mobile Handsfree Mode, set it to disable, and make sure the override checkbox is selected. Then select "Save, OK, Apply Config, OK." This disables the feature on the phone.
07-20-2017 02:53 AM
Hi - this forum primarily focuses on "Intelligent Proximity for Content Sharing", eg the one used with collaboration room systems. But, I've reached out to the phone team and asked if they could have a look.
My hunch would be there is a UCM-setting controlling this somewhere. You can also try to disable bluetooth alltogether; "Intelligent Proximity for Mobile Voice" (for the phones) is a BT-only feature.
And sorry for the confusing brand names here; this page tries to clarify:
http://cisco.com/go/proximity
Best regards,
Henrik
07-21-2017 12:32 PM
07-21-2017 12:56 PM
Thanks - disabling it works. Seems odd that a factory reset wouldn't also reset all known phone associations. Any chance there's a way to do that without disabling the feature?
07-21-2017 05:11 PM
Looks like this might require a key-sequence factory reset. I did a brief test and my initial test validates what you see when performing a factory reset using the GUI. However, if you do a key-sequence factory reset it turns off the slider for "Bluetooth" and "Hands-free 2-way audio" on the phone. To perform a key-sequence factory reset:
