Cisco Proximity Crashed
marcis.U
Unable to start Cisco Proximity application on macOS Big Sur Version 11.2.3
Tried reinstalling (the last installation was 26.04.2021) the application multiple times with no luck.
In the security and privacy, tab application is allowed to use Mic.
There is no Security application (McAfee, Trend, etc) installed on the computer.
The issue started around 2020 19th November and the application hasn't worked since.
Can anyone assist with this problem?
mneergaa
My apologies. This will be addressed in the next version of Cisco Proximity. I will update here once it's released, but it might take some a few weeks.
Just note that I don't know exactly why this would happen, but I suspect an update to macOS might have caused the change.
@mneergaa Is there any status on the update of the Cisco Proximity?
marcis.U
@mneergaa Thanks for a reply.
Waiting for the update then.
Just ping me when it is pushed that I could test if it works.
4.0.0 is out now!
