12-04-2018 04:37 PM
Hello All,
After reloading the 3750 switch with new version i was not able to access switch with the my login credentials.
Only with the admin credentials i was able to login into the switch!
I thought its a first time so it may require the admin password, but now no users was able to access the switch except the admin account.
Best Regards,
Sandy!
Solved! Go to Solution.
12-13-2018 10:05 AM
Hello All,
There was a change in the config after the reboot!
The Recent config was missing Key value of radius server.
After adding the key value, all the users was able to login with the domain account.
Cheers,
Sandy!
12-04-2018 06:09 PM
can you share your config. thx
12-04-2018 06:50 PM
12-13-2018 10:05 AM
Hello All,
Cheers,
Sandy!
