04-30-2024 06:44 AM
Hi. I tried different ISO image files and I used USB flash (2GB memory) to get out of ROMMON mode in my router ISR1100 4G.
I type in ROMMON mode dir usb0:
and then power off and power on the router, but I keep seeing this message: (Unsupported package header version (0))
You can see in the following what I got:
System Bootstrap, Version 17.7(1r), RELEASE SOFTWARE
Copyright (c) 1994-2021 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: PowerOn
ISR1100-4G platform with 4194304 Kbytes of main memory
ME is in Operational state
no valid BOOT image found
Final autoboot attempt from default boot device...
Located mode_event_log
Unsupported package header version (1869508461)
Located poweron_debug.txt
Unsupported package header version (1701013862)
Located .sdwaninstaller
unable to open bootflash:/.installer ->[NOT EXIST] /bootflash/.sdwaninstaller (1 4)
Located .sdwaninstallerfs
Failed to find bootable image on device bootflash:
Thanks.
Solved! Go to Solution.
04-30-2024 10:00 AM
If the version of old is good and router booting, format the flash and copy the working image to boot flash:
set boot image and write the config and reboot and check it should boot normally with out ROMMON
Once that is completed, then you need to Upgrade ROMMON, before you install 17.9.4a
check the release notes and ROMMON Upgrade :
04-30-2024 07:56 AM
When you get in to ROMMOM:
if you type dir usb0: ( do you see the file in the USB) this also bootflash:
try dir bootflash:
> boot bootflash:asrxxxx-universalk9.xxxxxxxxxxxxxx.bin
04-30-2024 08:40 AM
Thanks a lot. I got these when I typed:
rommon 12 > dir usb0:
0 0 drw- System Volume Information
0 685020580 -rw- c1100-universalk9.17.09.04a.SPA.bin
0 2571280 -rw- C1100-rommon-1612-1r-SPA.pkg
rommon 11 > dir bootflash:
0 0 drw- lost+found
0 0 drw- SHARED-IOX
0 0 drw- .prst_sync
0 346 -rw- mode_event_log
0 0 drw- pcap
0 0 drw- sysboot
0 197 -rw- poweron_debug.txt
0 0 -rw- .sdwaninstaller
0 0 drw- .rollback_timer
0 0 drw- core
0 0 drw- .USWAP
0 0 drw- .CRFT
0 0 drw- .ssh
0 0 drw- iox
0 0 drw- gs_script
0 419430400 -rw- .sdwaninstallerfs
0 0 drw- .sdwaninstaller
0 0 drw- EFI
0 0 drw- tracelogs
I tried:
rommon 14 > bootflash:c1100-universalk9.17.09.04a.SPA.bin
and
rommon 16 > boot bootflash:c1100-universalk9.17.09.04a.SPA.bin
unable to open bootflash:c1100-universalk9.17.09.04a.SPA.bin (14)
Do you have any suggestions?
04-30-2024 08:46 AM
> boot usb0:c1100-universalk9.17.09.04a.SPA.bin
if the image is good, then you it boots complate and you get #
04-30-2024 08:49 AM
Thanks a lot it worked but I get this message:
rommon 26 > boot usb0:c1100-universalk9.17.09.04a.SPA.bin
Located c1100-universalk9.17.09.04a.SPA.bin
Image Base is: 0x462B6018
Image Size is: 0x28D495A4
Package header rev 3 structure detected
Package type:30000, flags:0x0
IsoSize = 631123968
Parsing package TLV info:
000: 000000090000001D4B45595F544C565F - KEY_TLV_
010: 5041434B4147455F434F4D5041544942 - PACKAGE_COMPATIB
020: 494C495459000000000000090000000B - ILITY
030: 4652555F52505F545950450000000009 - FRU_RP_TYPE
040: 000000184B45595F544C565F5041434B - KEY_TLV_PACK
050: 4147455F424F4F544152434800000009 - AGE_BOOTARCH
060: 00000011415243485F61726D36346265 - ARCH_arm64be
070: 5F545950450000000000000900000014 - _TYPE
080: 4B45595F544C565F424F4152445F434F - KEY_TLV_BOARD_CO
090: 4D5041540000000900000010424F4152 - MPAT BOAR
0A0: 445F63313130305F5459504500000009 - D_c1100_TYPE
0B0: 000000184B45595F544C565F43525950 - KEY_TLV_CRYP
0C0: 544F5F4B4559535452494E4700000009 - TO_KEYSTRING
TLV: T=9, L=29, V=KEY_TLV_PACKAGE_COMPATIBILITY
TLV: T=9, L=11, V=FRU_RP_TYPE
TLV: T=9, L=24, V=KEY_TLV_PACKAGE_BOOTARCH
TLV: T=9, L=17, V=ARCH_arm64be_TYPE
TLV: T=9, L=20, V=KEY_TLV_BOARD_COMPAT
TLV: T=9, L=16, V=BOARD_c1100_TYPE
TLV: T=9, L=24, V=KEY_TLV_CRYPTO_KEYSTRING
TLV: T=9, L=10, V=EnCrYpTiOn
TLV: T=9, L=11, V=CW_BEGIN=$$
TLV: T=9, L=17, V=CW_FAMILY=$c1100$
TLV: T=9, L=46, V=CW_IMAGE=$c1100-universalk9.17.09.04a.SPA.bin$
TLV: T=9, L=22, V=CW_VERSION=$17.09.04a$
TLV: T=9, L=53, V=CW_FULL_VERSION=$17.09.04a.0.6.1697823731..Cupertino$
TLV: T=9, L=28, V=CW_CONTROLLER_VERSION=$20.9$
TLV: T=9, L=52, V=CW_DESCRIPTION=$Cisco IOS Software, IOS-XE Software$
TLV: T=9, L=9, V=CW_END=$$
Skipping unknown TLV type 13
Found DIGISIGN TLV type 12 length = 392
Unknown package structure
Failed to boot file usb0:c1100-universalk9.17.09.04a.SPA.bin
Aria
04-30-2024 09:12 AM
i am thinking based on informaiton you may need ROMMON Upgrade. (just guess)
can you download lower version of IOS XE like 16.12.X bin file and try to boot same way you did, copy to USB and boot and let us know.
also check @leo produced good document :
04-30-2024 09:28 AM
Thanks I used another image file and now I get out of ROMMON mode. Thanks a lot for that, that was a life saver.
should I now copy the ISO file in flash using commands like:
copy usb0:
I only set the username and password.
Aria
04-30-2024 10:00 AM
04-30-2024 10:13 AM
Thanks so much for your help.
Aria
04-30-2024 08:43 AM
Also, when I type 'boot' I get this message:
Image Base is: 0x55FFF018
Image Size is: 0x19000000
rommon 22 >
04-30-2024 06:31 PM
That's because the router was, initially, configured for SD-WAN and the router is booting a regular firmware (non-SD-WAN).
My recommendation is to format the flash while in ROMMON to wipe away all SD-WAN-related files and instructions. Boot the firmware from USB. Copy the firmware into the flash and perform an Install Mode upgrade.
Only when that is all done do the decision to convert the router back to SD-WAN (or not).
05-09-2025 06:51 AM - edited 05-09-2025 07:00 AM
Please ignore this comment,i reply to the wrong discusstion
