ARf player for Android
Sara.Amir
Hello I was wondering if there's a player for the webex recordings on Android devices? Or any other ARF player? Thanks.
11 Replies 11
mgervase
Hi there,
WebEx recordings are not available for playback on mobile WebEx apps. It still requires WebEx on the desktop for playback. Mobile playback is something we're looking at as a feature in the future.
Mark Gervase
Collaboration Marketing
leon.ip
WebEx has a Network Recording Player (nbr2player.msi) that can convert ARF to MP4
Amit Singh
Leon, webex has a convertor available WRF2WMV but it does not detect arf file format. Since Webex recording are available in .arf format I wonder what is this WRF file type then ?
Amit
A WebEx session can generate one of 2 recorded file types. You determine the file type you wish to generate when you create the recording:
  1. If you record your live WebEx session locally,  i.e. if you select Record on This Computer from within the live WebEx session, or if you use the offline WebEx Recorder, the result will be a .wrf file placed on your hard drive.  Use VoIP or a Dynametric Adaptor to capture the audio when recording via this method.
  2. If you choose to record your live WebEx session on the server, i.e. if you select Record on Server from within your live WebEx session, the result will be an .arf file placed on a WebEx server and accessible to you via your WebEx site.
I hope this helps,
Susan McEvilly
Meet Me In The Cloud
WebEx Coaching and Implementation Services
Saurabh Gupta
Level 3
Level 3
Hi All,
When Cisco would roll out Webex Player for ARF and WRF files playback on Android Devices?
Is there any other alternative or any other app ??
Saurabh
jaff_jeff
Hello, I was wondering if there's a player for the webex recordings on Android devices? Or any other ARF player? Please suggest if any one has used or explored ?
Or I have to go for Windows Tablet Only for playing WebEx Recordings ?
I need this very urgent, any one please share your inputs.
Jabbar
Just convert the WebEx recording to MP4 format or flash for Android and you can play it natively on mobile devices. There is no native player I have found
Srini
Hi Srini,
Thank you for the quick response. Just one last clarification, I want to play Some Tutorial of Web Ex which was recorded by third party in their END.
I just want to know can I able to convert it to MP4 Player or Adobe Flash Player in my END while playing on my Android Tablet ???
Or does it needs to be converted by my third  party ?
Jabbar
Download the ARF file. Open it with the WebEx player. Unde File you will see an option to save it in multiple formats such as MP4 or SWF, unless the person who created this file has disabled that ability. You can then convert to that format and play it on your mobile player
WebEx Player: Watch, share, and edit WebEx recordings.
My laptop is ubuntu 18.04, 64 bit.
I wanted to play .arf file on the same, I heard  that Network Recording player by default supports the conversion but I am not quite sure how this can be implemented in Unbuntu. I saw there are .msi version for windows available in website but there is not support for ubuntu.
Please guide if how I can play these files?
cdetorres
Is there really no way to view your recordings on your android mobile device without having to convert the file? This has been a topic of discussion since 2011, 10 years ago. I don't understand.  Please advise.
CD
