Attendant Console Advanced 12
CoDeC
we have upgraded to CUAC Advanced 12.0.5 and we have noted that in the clients disappeared the path in windows registry HLM\SOFTWARE\Wow6432Node\Arc Solutions
I know that in the new version some features can be changes in the client instead of registry but I don't find where is saved the server name configured in the installation process. In old version, it was easy to change the server with only change a key on the windows registry.
appreciated your advice
regards,
CoDeC
Finally  I have found the path C:\ProgramData\Cisco\CUACA where is located the xml configuration file OPR.config
In this file we can find the server where the client connect.
regards,
Alberto
