02-05-2019 02:05 PM - edited 03-17-2019 07:50 PM
02-06-2019 02:13 AM
Try to connect Analog Phone to one of the ATA port and see if you can make or receive calls
02-07-2019 09:18 AM
Check your Voice dialing first, attach an analog phone to the ATA and make sure you can make.receive calls, then you can move to faxing.
02-10-2019 02:49 AM
03-11-2019 02:05 PM
I am having a very similar issue. We are able to make calls to and from the fax machine even. It just isnt sending the fax data or the fax machine gives us a poor line condition error. If anyone has any ideas help would be very nice. I do currently have a case open with TAC as well and our PSTN service provider.
