Cisco Jabber SSO Timeout
reindl_mc
Hi Babu
Jabber with SAML SSO -- when you let the PC run over nights and days without shutdown
then you get some day a message that the session has timed out.
You have to shutdown and start again jabber for successful Login.
How can this issue be adressed ?
Kind regards
19 Replies 19
lior look
Level 5
Level 5
Hi there is any updates for this issue?
Please share the TAC number if exist..
I have the same on jabber 12.0(1) with cucm 11.5(1)su2 and ADFS
Reece
Getting this error on Jabber version 12.0.1 "Your current session has expired. Please renew the session to keep all your services working." !Error: Your session has expired. CJ:1000:606
We didn't see this error on older versions of Jabber, and SAML/SSO configuration hasn't change.
Is there something new that Jabber 12 is doing?
Confirming issue persists with Jabber 12.1.0 Build 266460.
On our second TAC case to resolve this, doesn't appear to be Bug CSCvg72905 as suggested.
Did you find a fix to this one?
Hi Reece,
Did you get this fixed? We're having the same issue. Actually, we're seeing the following errors:
Error Server Single sign on CJ:1000:500
Error:Your session has expired. CJ:1000:606
Jabber Version:12.9.5
Cheers
