Cisco vTS conference resource for CUCM on third party HP blade
saleem pc
We have Cisco CUCM 10.5 and ISR 4331 voice gateway. We are planning to buy few 8865 video IP Phones, how video conferencing can be done. the 8865 are small screen phones previously with PVDM3 video conference was possible what about PVDM4
We also got HP c7000 blade on VM Ware 6.5 ESXi, if we order vTS shall we install the OVA on HP VM, what else component required to make simple adhoc conference ?
or is there any MCU still selling by Cisco ?
Many thanks in advance for your help
Jaime Valencia
PVDM's no longer support video conferencing.
If you want to use vTP, you also need Conductor and they're both phasing out in favor of CMS.
Engage with pre-sales so they can suggest you what would be required to buy.
java
if this helps, please rate
Thanks alot
We already got uwl standard license. Conductor is included in uwl as per my understanding.
Appreciate if you can advise is the conductor and vTP supprted on third party hardware ?
Virtualization wiki has all that information, have you reviewed it?
java
Recommend you look at Cisco Meeting Server, as both Conductor and TelePresence Server are soon to be end-of-sale Feb 2018 (eos-eol-notice-c51-739456 and eos-eol-notice-c51-739457.html).  CMS is the replacement and recommended solution going forward, it can be run as a virtual appliance on pre-configured UCS or your own spec-based hardware.
