CSCvi59452 - IMandP 12.0.1 System Troubleshooter reporting LDAP error
networkexpert
Hi all ,
would you please advise regards the Bug "CSCvi59452"
as per the fixed release , the vsersion i'm using should be fixed however the issue still exist.
System version: 12.0.1.21900-3
I attached the error in server IM&P
please advise
nagaraj789
As its a bug, better to raise a TAC case to check the cause.
Jonathan Schulenberg
Also, be careful not to confuse CUCM and IM&P builds. I’m not aware of an IM&P build 21900-3 but that does match CUCM SU1.
