CUC CLI SQL Command Help
The following SQL Command will purge voicemails out of CUC for a single user's ('vmuser1' in the below) voicemail box between specified dates:
run cuc dbquery unitymbxdb1 update tbl_FolderItem set deleted = 1 where arrivaltime between '2023-01-01 06:00:00' and '2023-07-01 06:00:00' and folderobjectid = (select folderobjectid from tbl_folder where mailboxobjectid= (select mailboxobjectid from vw_mailbox where description='vmuser1') and folderinfoobjectid = (select folderinfoobjectid from tbl_folderinfo where name='Inbox'))
As I am not a SQL expert, so.... Can anyone help me with editing this command so that it will do the "set deleted = 1" within the arrival time but only if the current status is "Seen"?
So, essentially, voicemails that have been seen/listened-to that are older than a certain datetime will have their status changed to 'set deleted = 1'?
Thanks for your help!
Maren
Carlo Poggiarelli
Hi Maren
Here you are
run cuc dbquery unitymbxdb1 update tbl_FolderItem set deleted = '1' where seen = '1' and arrivaltime between '2023-11-01 00:00:00' and '2023-11-02 23:00:00' and folderobjectid = (select folderobjectid from tbl_folder where mailboxobjectid= (select mailboxobjectid from vw_mailbox where description='vmuser1') and folderinfoobjectid = (select folderinfoobjectid from tbl_folderinfo where name='Inbox'))
Carlo
Please rate all helpful posts "The more you help the more you learn"
9 Replies 9
Carlo Poggiarelli
Hi Maren
Here you are
Carlo
@Carlo Poggiarelli  - Thank you SO MUCH! I can't wait to try it out. -- Maren
(And I'll come back and mark it "Solution" providing it works - which I have no doubt it will!)
Carlo Poggiarelli
Hi Maren,
You are most welcome!
To convince you more 🙂 , here below you can find  a sequence that I've done on my lab.
Here you can  see that there is a seen message in today's time range
Here I marked as deleted the seen message.
...and last, the result.
Hope this is what you are looking for.
Cheers!
Carlo
That does work exactly as described, thank you so much @Carlo Poggiarelli !
While I am on the subject, do you happen to know a SQL command that will purge deleted items out of the database? Essentially, rather than waiting for the Message Aging Policy to purge deleted items after 1 day (which is what is currently set in our system), to have the system purge deleted items when I run the command?
Maren
Carlo Poggiarelli
Hi Maren
Thanks for your feedback
You can try to run the "run cuc sysagent task Umss.MessageAgingTask" command
Carlo
That one will immediately run the regular Message Aging Task, but does not "Clean Deleted Items" which is what I'm looking for. I've looked for such a command for some time, but come up empty. Thanks for getting back to me so fast.
Maren
Ok let's apply this trick.
Make the seen message a little old 😉
run cuc dbquery unitymbxdb1 update tbl_FolderItem set deleted = '1' ,arrivaltime ='2019-11-01 00:00:00',modificationtime='2019-11-01 00:00:00' where seen='1' and arrivaltime between '2019-11-01 00:00:00' and '2023-11-07 23:00:00' and folderobjectid = (select folderobjectid from tbl_folder where mailboxobjectid= (select mailboxobjectid from vw_mailbox where description='VMUSER1') and folderinfoobjectid = (select folderinfoobjectid from tbl_folderinfo where name='Inbox'))
than run run cuc sysagent task Umss.MessageAgingTask
That will do the trick 😉
Please let me know
Cheers
Carlo
ooooOOHHHHHOoooo! Making the modification date 'old'. That's sneaky and I like it. I doubt my customer would allow it, but I think I will give it a go in our development platform.
Thank you!
Maren
ahahah
I doubt your customer will complain with that cause you are going to delete his dated messages and that’s what he’s asking for
Cheers
Carlo
