CUCM pre-upgrade check error issue
nicanor00
I need to upgrade 11.0.1.21900-11 to 12.5.1.12900-115
I am using ESXI 7.03
I downloaded these 2 files and put it the SFTP server directories
ciscocm.preUpgradeCheck-00032.cop.sha512
ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn
but when I tried Install/upgrade with SFTP server I got error message (see attachement)
ciscocm.preUpgradeCheck-00032.cop.sha512ciscocm.preUpgradeCheck-00032.cop.sha512
Error encountered: An unknown error occurred while accessing the upgrade file. MD5 Hash Value:
Please kindly help to fixe it
I use filezilla server and it work
Thanks all
9 Replies 9
Jaime Valencia
You need to install the SHA512 keys in order to use sha512 files, the name of that file you're trying to install seems extremely long, seem like you modified the name and it's the same name twice, fix that. There are filters in the CUCM server and if a file doesn't adjust to those, it won't work.
java
if this helps, please rate
Thanks for your answer
1. where should I found the SHA512 keys
2. How should I install it ?
Please advise
This has been discussed many times at the forum, 5 minutes searching will provide all the info you need on that.
The install is the same as any other cop file.
java
The COP I am trying to install is the signing key for SHA512.
So why it doesnt work
Please help
Read my first comment again, I already said the filename looks wrong.
java
Jonathan Schulenberg
In addition to Jaime’s guidance, the upgrade guide calls for a second COP file when going from 11.0 to 12.5:
ciscocm.cuc_upgrade_12_0_v1.3.cop.sgn
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/12x/install_upgrade/guide/b_12xcuciumg/b_12xcuciumg_chapter_010.html#ID-2166-00000016
Thanks all
Yes, thanks. It work
this works. Sha512 is already there. previously I used solarwinds SFTP. with that name of the iso file gets duplicated. once I have used filezilla to upload the iso. it is getting uploaded with the correct name. So thumbs up to you.
