10-15-2013 05:52 PM - edited 03-17-2019 03:38 PM
We're in the pilot/test phase of a global MeetingPlace 8.5 deployment and would like to monitor node capacity utilization to see if I might need to add more to my cluster in my region. Is there a way for me to monitor SRU Utilization to see if I'm getting near node capacity as meeting attendees join?
THANKS!
Mike.
10-16-2013 05:20 AM
Hi Mike,
You can use the mbdstatus command, which usually takes a few seconds to update. Look for the
'UsedAudio =' which represents the SRU usage reported to the primary MBD. There are some other commands and details about them here:
Derek Johnson
Conferencing TAC
10-16-2013 07:21 AM
As always- thanks Derek!
