CWMS 2.0 SSL Certificate Issue on IOS device
wisit_jan
I have uploaded SSL Certificate to CWMS Server all device is worked fine but only IOS device is not work.
Error Code:100202
I think problem is certificate issue. I used SAN SSL *.domain.com
I obtain SSL Certificate and OrganizationSSL Root Certificate from GlobalSign SSL Certificate
I found in Trobleshooting Guide, they say "upload it to Cisco WebEx Meetings Server together with the end entity certificate".
How to "upload it to Cisco WebEx Meetings Server together with the end entity certificate"?
I follow step in https://supportforums.cisco.com/discussion/11794371/cwms-ssl-certificate-issue but not work
I  create .pem file and order content in same file
-----BEGIN PRIVATE KEY-----
… Private key …
-----END CERTIFICATE-----
-----BEGIN CERTIFICATE-----
… End entity certificate …
or
Private Key
CWMS Entity certificate
Intermediate Certificate #1
when upload file .pem occur error "The certificates do not form a valid certificate chain."
Please provide how to upload it to Cisco WebEx Meetings Server together with the end entity certificate?
2 Accepted Solutions
dpetrovi
Per the information provided, you have a Wildcard SSL certificate (*.domain.com) provided by GlobalSign, but when you upload it to CWMS with a file that contains the following:
Private Key
Wildcard cert
Root cert
you get an error "The certificates do not form a valid certificate chain." This is expected behavior since you shouldn't insert the Root cert, but instead you need to insert the Intermediate SSL cert from GlobalSign. Reach out to GlobalSign and obtain the appropriate Intermediate Cert: https://www.globalsign.com/repository/ca-certificates/ that match your Wildcard cert. Once you have that cert, then create a bundle:
Private Key
Wildcard cert
Intermediate cert
and upload it to the CWMS server. This should resolve the issue you are seeing on the iOS devices.
I hope this will be of help.
-Dejan
If you generated a CSR on CWMS server, then private key is stored on CWMS and you don't need to upload it. In that case, you would just need a valid SSL cert for CWMS, and a corresponding Intermediate certs.
… CWMS certificate …
… Intermediate certificate …
If you still get the same error, you are definitely not using the correct intermediate cert. Keep in mind that some CAs use primary and secondary intermediate certs, so you will have to include both. In that case, the order would be:
… Secondary Intermediate certificate …
… Primary Intermediate certificate …
-Dejan
9 Replies 9
dpetrovi
Private Key
Wildcard cert
Root cert
Private Key
Wildcard cert
Intermediate cert
-Dejan
How to bundle these three file? put Private Key, Wildcard cert, Intermediate cert in to 1 file right?
Private Key
Root Cert
when install certificate occur error message "The certificates do not form a valid certificate chain."
Don't use ROOT CERT. You need to use INTERMEDIATE CERT instead of ROOT. To bundle them, you create a .pem file with:
… Private key …
-----END PRIVATE KEY-----
I hope this explains it.
-Dejan
Hi Dejan,
The private key is obtain when Gen CSR right?
I uploaded file in order but still show same error message "The certificates do not form a valid certificate chain."
-Dejan
Hi Dejan,
Now it work
GlobalSign sent me a wrong Intermediate Certificate. I download new Intermediate Certificate from GlobalSign (https://support.globalsign.com/customer/portal/articles/1219303-organizationssl-intermediate-certificates)
And create pem file in order
... End entity certificate ...
... Intermediate certificate ...
Thank you very much for your support. I get more idea from you
I am happy to hear that you were able to upload the appropriate chain. Is the issue with the iOS device now resolved (it should be)?
Thank you.
-Dejan
Hi Dejan,
Yes, now resolved with iOS devices
Just wanted to give feedback to this post as I came across this to fix my issue. I am running 2.5 of CWMS and they changed the format. It now looks like:
----Private Key---
Private key info
---end private key---
---Intermediate key----
Intermediate infor
---end intermediate key---
---Entity certificate---
certificate info
----end entity certificate----
I also used this site to help extract out the information I needed from the encrypted files I was given by the customer:
https://ril3y.wordpress.com/2014/01/22/ssl-with-intermediate-certificates-for-on-premise-webex/
-The Hoff
