12-05-2015 01:33 AM - edited 03-17-2019 05:43 PM
Hi.
First of all thanks to WebEx team, nice move. I have one simple question for someone inside the
BU. It looks like not all of the audio prompts are available to customize (or they are hidden and not
included in the list). I'm looking for one particular prompt on the beginning of "blast audio conference".
It says: "Enter your PIN followed by pound to start the meeting". Yes, right it's silly I know. :)
Thanks.
Solved! Go to Solution.
12-05-2015 05:44 AM
12-05-2015 05:44 AM
This is the prompt: 3001.wav.
-Dejan
12-05-2015 02:49 PM
Great Dejan, I'll definitely give it a try :)
01-08-2016 06:04 AM
Hello Dejan,
I am trying to localise "Blast Dial" announcements.
So I couldn't find those lines on "administrationguide_extentedbranding.pdf"
Can you say which wav files includes those prompts.
You are the meeting host, participiant beeing connected.
Press 1 to the connected to be your meeting
Press *2 decline to call
Press *3 remove your phone number from this calling list.
Baris
01-09-2016 10:16 AM
Hi Baris,
You can use this document to see the list of all the prompts on CWMS: http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_6/Administration_Guide/Administration_Guide/Administration_Guide_chapter_01110.html#reference_55D22C0DE1C8432C9D4742AA8FB3FED2
Press one to be connected to your meeting = 3015.wav
Some of these prompts are combinations of multiple prompts.
For example:
Press *2 = 351.wav
To decline the call = 3016.wav
To remove your phone number from the calling list = 3017.wav
and so on.
I hope this will help you find the prompts you are interested in.
Kind regards,
-Dejan
01-11-2016 07:26 AM
Hello Dejan,
Thank you for reply.
My poc done now.
Baris.
