I have CUCM 7.1.5 and it is configured to work with Jabber for Android. Jabber client is registering with CUCM and working fine.
I want to have customidez dial rules for jabber,so I followed cisco document to configure it
- first I instaled the COP file to CUCM
- downloaded the appdialrules.xml, modify it and saved with different name
- uploaded the modified XML to tftp server in CUCM and restarted the tftp service
- then, in the BOT device's "Application Dial rules URL" field I put the value as "http://CUCM_IP_ADD:6970/myappdialrules.xml" (whent I type this in browser I can see the XML)
But when I dial a number in jabber client dial rules are not applied. I created the Dial rule as below
<DialRule BeginsWith="5" NumDigits="4" DigitsToRemove="0" PrefixWith="6"/>
so when I dial 5335 on Jabber it should dial 65335 extension, but it is not working
Whatis the problem here?
pls help me
