Disable manual speed dial setup for 88XX series
cdevkota-sc
I would like to disable manual speed dial on 88XX series phone. Is there any option available for this?
Jaime Valencia
No
java
if this helps, please rate
I don't know of an administrative menu to accomplish this. But if it is just a few phones - or if it is all of them - you might try setting up a Phone Button Template where the un-used buttons are set to "None" as a purpose rather than "Speed Dial".
Maren
Mahmoud Belhaj
you could change it to none by setting up a Phone Button Template
