Expressway E public CA for DX and jabber MRA
Kevin100
Hai
I am confused about public certificates choosing for DX and jabber MRA on expressway E.
Can any one recommend exact version go daddy or digicert.
Which dns should use collabedge or dns? Also server certificate need to be signed ?
Thank you
Jaime Valencia
DNS and SRV requirements are outlined in the MRA configuration guides, certificates requirements are also within that document, and there's a whole separate document for certificates guidelines. Have you reviewed both docs?
java
if this helps, please rate
Dear Jaime
Thanks for the reply.i went through all documentation.But confused of vendors and their offering.I purchased quick ssl premium but San field is missing on signed certificate.Also online srv validation shows top level domain and _tls.. not there
I need to know which provider which certificate compactable also work with DX as it contains some root ca
Then you want to discuss this with the CA you chose, explain them what specs you need in the certificate so they can point you to the right offering.
As for the SRVs, then you need to discuss wit your DNS provider to make sure they're all properly populated.
java
