Expressway edge cert renew
Hi guys
I tried to renew the certificate for cisco express way E , i generate a CSR and sign it through Godaddy , when i try to upload the new root certificate and cerver cert , but it's faild , i receive the following message , please any one know what exactly the issue ?
b.winter
You should read the error message. The certificate you got doesn't match the private key (which was generated when you generated the CSR).
Maybe GoDaddy generate a new private key for that cert, which maybe you also got from them in the file.
Or someone generate a new CSR, which makes the old CSR and private key invalid.
The certificate generated from go daddy will not be using the CSR you generated from CSR. use the option to upload the CSR or copy past the CSR while generating the Certificate.
Or it can be as @b.winter mentioned some one might have generated another CSR.
Response Signature
