Jabber calls through the Expressway-C/E (MRA) , CUCM does not applay any transformations to Calling Number
Plu05wrnn
Hello
We have strange issue with Jabber registered thorugh the MRA in CUCM. When registered from interenet Jabber is not applaying any Calling Number trasnformations. When i call other phone (internal or PSTN , no difference)  i can see on the called device only my direct line number ringing even if there is a special Calling Party Transformation Pattern used to transform my Calling number.
When the sama Jabber is registered in LAN CUCM is applaying all translations properly.
Do you have any ideas what could be the reason ?
Thank you !
Tomasz
Ayodeji Okanlawon
Perhaps this is not supported. I suggest you open a TAC case and ask the engineers. Please update us
Please rate all useful posts
Hi Sr
Some update for this case??'
