Jabber in phone-only mode connectivity issue via MRA
Emmanuel Akum
I'm getting a 502 response code when trying to connect with Jabber via MRA and can't figure out why this is happening.
From Jabber Logs
I'm get  a 502 response code when [csf.httpclient] [csf::http::performRequest] - *-----* HTTP response code 502 connect code
From Expressway E logs
traffic_server[2044]: Event="Sending HTTP error response" Status="502" Reason="connect failed" Dst-ip="x.x.x.x" Dst-port="57395" UTCTime="2022-07-07 22:51:52,999"
Jabber is deployed in phone-only mode. There is no IMP Server.
Expressway is deployed in a cluster
There are no issues when connecting internally/ directly to the CUCM
Expressway C Nodes are in the same subnet as the CUCM Nodes. There is no firewall between them.
There are no issues connecting 88XX phones via MRA
Adam Pawlowski
I've only ever seen this error code in the past when a UCM subscriber is not reachable from the Expressway C, when it was offline or a needed service was not running. I don't believe the 8800 series phones use User Data Service (UDS) when connecting through the Expressway, perhaps that service is not running on a UCM? I am just speculating, but, the solution isn't really aware when a service is shut off, node is down, etc and assumes you have everything available for it to run.
User Data Service (UDS) is running on all the nodes in the CUCM cluster
