06-14-2018 01:04 PM - edited 03-17-2019 07:35 PM
On Apple devices, Any Connect is used as a VPN client and then access to voice and instant messaging services. While using a Wi-Fi network as a means, all services start without problems.
However, when using a mobile data plan, even though the VPN connection over Any Connect works and has connection to the internal network, the services do not start.
Attach a couple of images with both cases.
Any suggestions that might be causing the services not to work while you are not connected to a Wi-Fi network?
06-14-2018 01:21 PM - edited 06-14-2018 01:22 PM
Hi there
From the screenshots, I can see that your cellular provider is T-Mobile. I saw the exact same issue on this thread for Apple devices while connecting via LTE or 4G. Android devices works fine.
https://www.reddit.com/r/Cisco/comments/7hnj57/issues_with_cisco_jabber_mobile_on_tmobile_data/
The solution says, T-Mobile assigns ipv6 addresses natively, with ipv4 support provided through some form of carrier grade NAT or other ipv4 tunnel. Some ipv4 servers/services don't like that. I had the same issue with my OpenVPN server on T-Mobile's LTE network because I didn't have AAAA records setup in DNS (for ipv6 name resolution). Once I created the AAAA record and pointed my VPN client at that address rather than the ipv4 A record, it worked perfect.
Also try upgrading the IOS to latest and Jabber as well.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
