Jabber not saving contacts in Allow/Block Lists under Advanced Privacy
ahaug
Is there a setting I have to set in CUCM to allow users to use the Allow/Block lists in Advanced Privacy? I add a user to the list and hit apply then the entry disappears.
I'm using Jabber 14.0.2 on Windows and using CUCM 12.5.1.11900-146. Any insight would be appreciated. Thanks
Vaijanath Sonvane
Hi @ahaug,
This seems to be an issue on Jabber version 14.0.1 and 14.0.2. It works fine on Jabber version 14.0.0 and earlier. I wasn't able to find software bug ID. I would recommend to open Cisco TAC case and highlight the issue with them.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
