Jabber on wifi issue
Sonam
I have two domains for jabber. External domain with expressway edge and internal domain used for within LAN. desktop jabber is ussed. i have created hotspot from lan desktop to login jabber. I could login but voice is just one way. it works when external domain with expe is used. Please help me on this!!
Jaime Valencia
Most one way audio or no audio issues are routing issues, start there.
java
if this helps, please rate
George Sotiropoulos
You need to check the routing between the interfaces on your Expressway-E, especially if it is a 2-NIC implementation.
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
