Jabber Phone Mode
Ritesh Desai
Hi team,
Need your guidance...
Followed URL: https://www.cisco.com/c/en/us/support/docs/unified-communications/jabber-windows/116446-technote-product-00.html#anc6
On-Premises Deployment
msiexec.exe /i CiscoJabberSetup.msi CLEAR=1
 PRODUCT_MODE=Phone_Mode TFTP=1.2.3.4 LANGUAGE=1033 /quiet
Infrastructure in my LAB:
  • CUCM: 11.0.1 SU3
  • IM & Presence: 11.0.1. SU1
  • Jabber Client 11.5 on Windows 8
  • Jabber Client 11.9 on Windows 7 Professional
Manually shutdown the IM and Presence server assuming there is no IM & Presence to see whether jabber communicates with CUCM and Jabber allows to login. But it failed.
Thanks & Regards,
Ritesh Desai.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Jaime Valencia
The fact that you shut down the IM&P DOES NOT mean your Jabber will then use phone mode, that's not how this works.
In order to use Jabber in phone only mode, you need to make sure that in the user page you do not check the option to enable him for IM&P, and that the service profile does not contain an IM&P server.
Rest of the CUCM config (device, device/line/user association, etc.) needs to be properly configured.
java
if this helps, please rate
Jaime Valencia
java
Hi JAVA...
Cheers... Solved!
So,
1. Removed IM Presence Profile and created new profile with Active Directory and CTI.
2 Assign the new profile to user.
Bang. it worked!!
thanks & regards,
Ritesh Desai.
