05-04-2017 01:43 AM - edited 03-17-2019 06:50 PM
hi there,
My jabber is showing some other language and location.
when
is this my windows problem or something else.
I
I tried to look solution on youtube but can find anything.
So if anyone know to whom should i contact please reply me.
Solved! Go to Solution.
05-04-2017 06:48 AM
You should reach your local IT department for this so they can investigate your problem.
05-04-2017 06:40 PM
sounds like its installed with the wrong language.
uninstall it an reinstall, choosing english as the language.
there is no option within Jabber to change the language, this is all done through the installer package
Please rate if useful
05-04-2017 06:48 AM
05-04-2017 06:40 PM
05-04-2017 10:19 PM
Thank you
09-05-2017 10:50 PM
Thank you all for your valuable time to find solution for my issue. You all are very helpfull.
