Jabber Push Notification delay
HRS
Jabber Push Notification delay causing voice call to drop before push notification reaches the iPhone. It appears that we are hitting this issue below
If there is a delay in the Push Notifications process that prevents Unified CM from offering the call to the IOS device, Unified CM drops the call after 13 seconds.
This is an intermittent issue where, in most cases, the iPhone mobile jabber begins to ring just as the Unified CM system is dropping the calIs there a way to increase the timer to accommodate the Push Notification delay or are there any recommendations?
On Both successful and failed calls, we received RESPONSE_PUSH_NOTIFICATION with Status 200 from Cisco Cloud for REQUEST_PUSH_NOTIFICATION without delay.
CUCM Version 12.5SU7a
Had issues before upgrade as well. Affected users are on both internal network and external network via MRA.
16 Replies 16
Eric Tucker
When you say 'internal network' would that also include simless devices?
HRS
Thank you All for the responses.
Local Push Notification is our solution here
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/push_notifications/cucm_b_push-notifications-deployment-guide/cucm_b_push-notifications-deployment-guide_chapter_01.html#local-push-notification-service-overview
Local Push Notification Service
Important
This section is applicable from Release 14SU3 onwards.
Note
  • iOS devices running on iOS16.5 or later with Webex App 43.6 or later or Cisco Jabber 14.2 or later support this feature. Ensure that your iOS device is connected in on-premises mode.
  • In this release, Local Push Notification Service (LPNS) supports notification for voice calls only.
  • LPNS is not supported on Android devices and MRA users.
    Important
    Note
