03-21-2020 02:16 PM - edited 03-21-2020 02:17 PM
Hi. Using Jabber 12.6, on a PC that is also USB-connected to a Plantronics SAVI W710. When a call comes in, or when placing a call, I'd like to quickly be able to switch between mic and speaker profiles depending on whether I want to use my headset or the laptop hardware. Is this possible? Climbing down into the options menu is too many steps when a call is coming in.
Ideally it would be nice to have a drop down on the answer button or when calling to choose from hardware profiles.
Open to workarounds - is there a CLI I could make a command file for to get there?
Thanks!
Solved! Go to Solution.
03-22-2020 09:34 AM
Once you're on a call there is an option to change the audio right there, but there are no profiles as you ask, you can submit a PER for this
03-23-2020 01:10 AM
03-22-2020 09:34 AM
03-22-2020 10:05 AM
Thanks Jaime. Is there a CLI for Jabber? I know there is for installation switches, but didn't know if there was a set for once running.
03-23-2020 01:10 AM
There is no CLI for Jabber.
