Bookmark
Subscribe
869
Jabber - switch mic and speaker on per-call basis
Hi.  Using Jabber 12.6, on a PC that is also USB-connected to a Plantronics SAVI W710.  When a call comes in, or when placing a call, I'd like to quickly be able to switch between mic and speaker profiles depending on whether I want to use my headset or the laptop hardware.  Is this possible?  Climbing down into the options menu is too many steps when a call is coming in.
Ideally it would be nice to have a drop down on the answer button or when calling to choose from hardware profiles.
Open to workarounds - is there a CLI I could make a command file for to get there?
Thanks!
2 Accepted Solutions
Jaime Valencia
Once you're on a call there is an option to change the audio right there, but there are no profiles as you ask, you can submit a PER for this
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime.  Is there a CLI for Jabber?  I know there is for installation switches, but didn't know if there was a set for once running.
There is no CLI for Jabber.
Response Signature
