Jabber / Unity connection
alialjamri2008
Can we get Jabber work with Unity connection, and what are the requirments and configuration?
Ali
Aaron Harrison
Yes, you need to enable IMAP on the Unity subscribers' class of service, and then add the Unity Conn server to a voicemail profile in CUPS.
It's in the admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_010.html#task_B4621AC86E8548C58464E343E3148288
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Is CUPS server required?
Ali
Yes, you need CUPS or Webex Connect for Jabber.
Aaron
