Are you using findme and you you have a findme URI which is {emailaddress}?
This at least would cause what you described.
Also define "I created a phone book with movi contacts". Did you use a provisioning directory phonebook source or something else?
In general it can be fine to use the email address if the user and domain part reflect on what you want to dial / findme.
Martin
