On Gateway, What is AdvUCSuiteK9? (Advanced UC Suite K9) -- Licensing question.
gretchen1983
Beginner
Beginner
Can you tell me why AdvUCSuiteK9 says "EvalRightToUse" and not "Permanent"?
Hopefully we installed the licenses correctly.  Is there a way to confirm this?
From a little research it looks like AdvUCSuiteK9 should automatically switch from "EvalRightToUse" to just "RightToUse" after the 60 days is up, but this is not very clear. But why does uck9 have two entries -- "Permanent" and "EvalRightToUse" ?
Is uck9 part of AdvUCSuiteK9.  Did we install something wrong or forget something for AdvUCSuiteK9, or do we just have to wait for the 60 days to pass?
show license detail
Index: 1 Feature: AdvUCSuiteK9                      Version: 1.0
                License Type: EvalRightToUse
                License State: Active, In Use
                    Evaluation total period: 8  weeks 4  days
                    Evaluation period left: 8  weeks 1  day
                    Period used: 2  days 0  hour
                    Transition date: Nov 30 2018 15:14:51
                License Count: Non-Counted
                License Priority: Low
                Store Index: 4
                Store Name: Built-In License Storage
Index: 8 Feature: uck9                              Version: 1.0
                License Type: Permanent
                License Suite: AdvUCSuiteK9
                License Priority: Medium
                Store Index: 1
                Store Name: Primary License Storage
Index: 9 Feature: uck9                              Version: 1.0
                License State: Inactive
                    Evaluation period left: 8  weeks 4  days
                    Period used: 0  minute  0  second
                License Priority: None
                Store Index: 1
luarroyo
Use command "Router# license right-to-use move AdvUCSuiteK9"
Gregory Brunn
Collaborator
Collaborator
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.pdf On Gateway, What is AdvUCSuiteK9? AdvUCSuitesK9 is Cisco One Suite Licenses that includes uck9, cme-srst, cube. Can you tell me why AdvUCSuiteK9 says "EvalRightToUse" and not "Permanent"? It says EvalRightTOuse and not permanent because it Eval and will transition to perminate. Is there a way to confirm this? You license looks good to me if you ordered UCK9 Why does uck9 have two entries -- "Permanent" and "EvalRightToUse" ? If you look at your index one is just inactive it is not used just showing that you had an evalright to use and then installed the UCK9 afterwards it is just a different index. Is uck9 part of AdvUCSuiteK9? No it is Cisco one suite of licenses Did we install something wrong or forget something for AdvUCSuiteK9, or do we just have to wait for the 60 days to pass? If your not using Cisco one licensing your fine. If you are your fine as well in my opinion. I don't think you did anything wrong
luarroyo
Recognize Your Peers
