Presense not showing
Pragash22
Hi All
Please refer to the attachment. Some phones in the call manager showing the Presense and some are not.
on the image the shot was taken in 8841 phone and 20124 is 8845 Model.
40307, 20131 and 89006 are 7941, 7942 and 7962 in order.
SUBSCRIBER CSS also same on the entire cluster for all phones and under enterprise parameters BLF for Call Lists also enabled.
Kind regards
Pragash
Ratheesh Kumar
Hi there
Can you check the monitoring CSS under the line of that phone.
Also I assume the presence group is configured
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
