Room Device(Roomkit pro) registered with Webex (L-KITPRO-MS)
soohyung choi
L-KITPRO-MS (embedded multipoint)
If the roomkit pro registered with webex ,but we can't do multisites conference using L-KITPRO-MS (embedded multipoint license)
Method is unknown. I'd like to know how.
Thank you
2 Accepted Solutions
Vaijanath Sonvane
If your endpoint is registered with following call control applications and if you do not have separate MCU resources, then you need embedded MultiSite license to do multi-point ad-hoc video conference.
  •  Cisco Unified Communications Manager (CUCM)
  • Cisco TelePresence Video Communication Server (VCS)
  • Third-party H.323 gatekeepers and standards-based SIP proxies
When you register your endpoint with WebEx Cloud, you do not have option to add other video participants manually. In this case MultiSite license is of no use.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
You are most welcome!
Vaijanath Sonvane
Thanks your help
Ratheesh Kumar
Hi there
For webex devices to use conference feature, you have to use the Webex bridge and use the SIP URI or phone number to dial-in. Thats the only option.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
