simultaneous active calls sessions on with jabber guest
Hello people,
I try to find out how many parallel active call sessions can I have with jabber guest. Can you please tell me where to look to figure it out?
Cisco Jabber Guest: main_11.1.2.11
Exressway c X8.11.4
Expressway e X8.11.4
Eleftheria
Yes, that's correct.
If you use B2B calling on this Expressway-Pair too, then Jabber Guest calls and B2B calls will share these 3 licenses. If you don't use B2B calling, then Jabber Guest can use all of those 3.
So, you can up to 3 concurrent "traversal" calls.
b.winter
With Jabber Guest, the limiting factor are the RMS licenses installed in EXP-C and EXP-E.
So, check the installed RMS licenses and the count will give you the max. concurrent calls the Expressways will handle.
Hi b.winter!
Thank you for your answer!
I see on expreesway e
Current licenses
Rich Media Sessions 3
TURN relay usage 1800
And on expressway c
Current licenses
So that means that can be up to 3 simultaneous active call sessions with jabber guest?
Eleftheria
