Spark SSO Bypass URL
petraraab
the Signing and Encryption Certificate of our SSO ADFS changed automatically. Now nobody can login to the url https://admin.ciscospark.com/#/login to update the trusted metadata file. Is there a way to Bypass SSO using a kind of recovery URL? Tried to search the community but did not found anything.
Petra
mh1983
Hi Petra,
I consulted with some experts and got a response:
The answer is to have their partner log in as admin and disable SSO. Then their local admin can test their local spark password and redo the sso config.
Hope this helps,
Marc
Hi Marc,
A Call in the US Support Team of Spark solved the Problem. They deactivated SSO for us, so we could reconfigure it.
Petra
