Why is webex dependent on the operating system ?
I recently started to get the following message when trying to join WebEx from Internet Explorer 8 on a Win XP laptop. But I wonder why a browser based collaboration tool is depending on the Operating System ?
Is there a workaround ?
You cannot use WebEx because your operating system is not supported. We recommend that you upgrade to a supported operating system. Refer to the WebEx release notes for information about supported operating systems
Gordon Ross
Level 9
Level 9
This is where you enter the magical word of marketing...
WebEx is web "based" in that:
  • Your initial access is via a web browser.
  • The communication happens over a HTTP connection.
Really, thought, the main WebEx client is a binary and you get a different binary depending on your platform.
GTG
Please rate all helpful posts.
