James Liao
This VG is connected with CUCM via MGCP. On the CM, GW has been registered.
I don't think I can get the inbound correctly. Any suggestion with below configure:
interface BRI0/1/0
no ip address
isdn switch-type ntt
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
end
dial-peer voice 1 pots
incoming called-number 34575243
direct-inward-dial
port 0/1/0
dial-peer voice 100 voip
destination-pattern 34575243
session target ipv4:192.168.1.10
codec g711ulaw
voice translation-rule 1
rule 1 /0/ //
Here are the debug q931 and isdn status:
ISDN BRI0/1/0 interface
dsl 4, interface ISDN Switchtype = ntt
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 67, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 4 CCBs = 0
The Free Channel Mask: 0x80000003
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 5. Layer 3 output may not apply
*Jul 13 05:33:38.481: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x A6
*Jul 13 05:33:53.369: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x26
Cause i = 0x8090 - Normal call clearing
James
8 Comments
MULTIPLE_FRAME_ESTABLISHED means your BRI is up.
if your gateway is MGCP, there is no need of dial peers.
From  debug message , I see normal call clearing.
what's the issue you currently facing ?
James Liao
Thank you for your reply.
Are you sure you don't need dial peer configure in the VG? Now, I am testing remotely, I will visit our LAB and find out if the incoming call really get through.
My questions is my configuration parameter is configured correctly.
James
since you have configured your gateway as MGCP, CUCM will control the BRI. you don't need a dial peer or voice translation.
Since the BRI status is up, configuration related to the MGCP is correct .
Make some test calls, if you face any issue let us know.  you may need some  fine tuning.
James Liao
Hi, I was told that MGCP GW in CUCM will not be support with NTT for BRI connection... Therefore, I have changed the MGCP to SIP trunk. Currently is full service.
I have run some debug on isdn q931, voip ccapi inout. Basically, from my cell phone, I can always reached 0334575243 but this DDI should translate to IP phone ext 2010. So, the IP phone never get the ringtone.
As for the outbound from the IP phone, I can call my cell phone with ringtone. but the cell phone never ring...
Any idea or suggestion?
*Jul 17 07:33:41.741: //-1/7493CB800000/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=2010
----- ccCallInfo IE subfields -----
cisco-ani=2010
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=008043801688
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Jul 17 07:33:41.741: //-1/7493CB800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3EC95ACC, Call Info(
Calling Number=2010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=008043801688(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=152
*Jul 17 07:33:41.741: //-1/7493CB800000/CCAPI/ccCheckClipClir:
In: Calling Number=2010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=2010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Jul 17 07:33:41.741: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 17 07:33:41.741: :cc_get_feature_vsa malloc success
*Jul 17 07:33:41.741: cc_get_feature_vsa count is 1
*Jul 17 07:33:41.741: :FEATURE_VSA attributes are: feature_name:0,feature_time:586683840,feature_id:21
*Jul 17 07:33:41.741: //152/7493CB800000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=2010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=008043801688(TON=Unknown, NPI=Unknown))
*Jul 17 07:33:41.741: //152/7493CB800000/CCAPI/cc_process_call_setup_ind:
Event=0x3EF29CD0
*Jul 17 07:33:41.741: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 008043801688
*Jul 17 07:33:41.741: //152/7493CB800000/CCAPI/ccCallSetContext:
Context=0x39F32294
>>>>CCAPI handed cid 152 with tag 2 to app "_ManagedAppProcess_Default"
*Jul 17 07:33:41.741: //152/7493CB800000/CCAPI/ccCallProceeding:
*Jul 17 07:33:41.745: //152/7493CB800000/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1, Params=0x39F3389C, Progress Indication=NULL(0)
*Jul 17 07:33:41.745: //152/7493CB800000/CCAPI/ccCheckClipClir:
Destination Pattern=0T, Called Number=008043801688, Digit Strip=TRUE
Redirect Number=, Display Info=
Account Number=2010, Final Destination Flag=TRUE,
Guid=7493CB80-0001-0000-0000-00030A01A8C0, Outgoing Dial-peer=1
*Jul 17 07:33:41.745: //152/7493CB800000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=2010
cisco-ani=2010
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=008043801688
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jul 17 07:33:41.745: //152/7493CB800000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3F44FECC, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=2010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=008043801688(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Jul 17 07:33:41.745: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 17 07:33:41.745: :cc_get_feature_vsa malloc success
*Jul 17 07:33:41.745: cc_get_feature_vsa count is 2
*Jul 17 07:33:41.745: :FEATURE_VSA attributes are: feature_name:0,feature_time:586683616,feature_id:22
*Jul 17 07:33:41.745: //153/7493CB800000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Jul 17 07:33:41.745: //153/7493CB800000/CCAPI/ccCallSetContext:
Context=0x39F3384C
*Jul 17 07:33:41.745: //152/7493CB800000/CCAPI/ccSaveDialpeerTag:
*Jul 17 07:33:41.749: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x9 is 0x0 0x0, Calling num 2010
*Jul 17 07:33:41.749: ISDN BR0/1/0 Q931: Sending SETUP callref = 0x0001 callID = 0x8003 switch = ntt interface = User
*Jul 17 07:33:41.749: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Calling Party Number i = 0x0081, '2010'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '008043801688'
*Jul 17 07:33:41.885: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
*Jul 17 07:33:41.885: //153/7493CB800000/CCAPI/cc_api_call_proceeding:
Interface=0x3F44FECC, Progress Indication=NULL(0)
*Jul 17 07:33:42.045: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x81
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Jul 17 07:33:42.045: //153/7493CB800000/CCAPI/cc_api_call_disc_prog_ind:
Cause Value=28, Progress Indication=INBAND(8), Interface=0x3F44FECC
Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
*Jul 17 07:33:42.045: //152/7493CB800000/CCAPI/ccCallDiscProgInd:
Call Entry(Responsed=TRUE, Disconnect Cause=28)
*Jul 17 07:33:42.045: //152/7493CB800000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x98, gcid=AC149AAF-C73611EA-80D7FDA0-7C21A54E, tag=0x0)
*Jul 17 07:33:42.045: //153/7493CB800000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x99, gcid=AC149AAF-C73611EA-80D7FDA0-7C21A54E, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=152, Call Id2=153, Tag=0x0
*Jul 17 07:33:42.045: //152/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:33:42.045: cc_api_get_xcode_stream : 4983
*Jul 17 07:33:42.045: //152/7493CB800000/CCAPI/cc_api_bridge_done:
Conference Id=0x1, Source Interface=0x3EC95ACC, Source Call Id=152,
Destination Call Id=153, Disposition=0x0, Tag=0x0
*Jul 17 07:33:42.049: //153/7493CB800000/CCAPI/cc_api_bridge_done:
Conference Id=0x1, Source Interface=0x3F44FECC, Source Call Id=153,
Destination Call Id=152, Disposition=0x0, Tag=0xFFFFFFFF
*Jul 17 07:33:42.049: //152/7493CB800000/CCAPI/cc_generic_bridge_done:
*Jul 17 07:33:42.049: //152/7493CB800000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1, Destination Call Id=153)
*Jul 17 07:33:42.049: //153/7493CB800000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1, Destination Call Id=152)
*Jul 17 07:33:42.049: confID:0x1; callEntry1 callID1:0x98, type:3; callEntry2 callID2:0x99, type:6
*Jul 17 07:33:42.049: //153/7493CB800000/CCAPI/cc_api_caps_ind:
*Jul 17 07:33:42.049: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
*Jul 17 07:33:42.049: sprt_latency 200, sprt_retries 12
Destination Interface=0x3EC95ACC, Destination Call Id=152, Source Call Id=153,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*Jul 17 07:33:42.049: //152/7493CB800000/CCAPI/cc_api_caps_ind:
*Jul 17 07:33:42.049: voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voice_sprt_payload 120
Destination Interface=0x3F44FECC, Destination Call Id=153, Source Call Id=152,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
*Jul 17 07:33:42.049: //152/7493CB800000/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1922)
*Jul 17 07:33:42.049: //153/7493CB800000/CCAPI/cc_api_caps_ack:
*Jul 17 07:33:42.049: //152/7493CB800000/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=152
*Jul 17 07:33:42.049: //152/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:33:42.049: cc_api_get_xcode_stream : 4983
*Jul 17 07:33:42.053: //152/7493CB800000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1, Call Id1=152, Call Id2=153
*Jul 17 07:33:42.053: //153/7493CB800000/CCAPI/cc_api_voice_mode_event:
Call Id=153
Call Entry(Context=0x39F3384C)
*Jul 17 07:33:49.105: //152/7493CB800000/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x3EC95ACC, Call Id=152
Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
*Jul 17 07:33:49.109: //152/7493CB800000/CCAPI/ccConferenceDestroy:
Conference Id=0x1, Tag=0x0
*Jul 17 07:33:49.109: confID:0x1; callEntry1 callID1:0x98, type:3; callEntry2 callID2:0x99, type:6
*Jul 17 07:33:49.109: //152/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:33:49.109: cc_api_get_xcode_stream : 4983
*Jul 17 07:33:49.109: //153/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:33:49.109: //152/7493CB800000/CCAPI/cc_api_bridge_drop_done:
*Jul 17 07:33:49.109: //153/7493CB800000/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=152, Disposition=0x0, Tag=0x0
*Jul 17 07:33:49.109: //152/7493CB800000/CCAPI/cc_generic_bridge_done:
*Jul 17 07:33:49.109: //153/7493CB800000/CCAPI/ccCallDisconnect:
Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
*Jul 17 07:33:49.109: //153/7493CB800000/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
*Jul 17 07:33:49.109: //152/7493CB800000/CCAPI/ccCallDisconnect:
*Jul 17 07:33:49.121: //152/7493CB800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EC95ACC, Tag=0x0, Call Id=152,
Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Jul 17 07:33:49.121: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 17 07:33:49.121: :cc_free_feature_vsa freeing 22F815B8
*Jul 17 07:33:49.121: vsacount in free is 1
*Jul 17 07:33:49.129: //153/7493CB800000/CCAPI/cc_api_call_disc_cause_update:
Cause Value=28
Call Entry(Disconnect Cause=28)
*Jul 17 07:33:49.133: //153/7493CB800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3F44FECC, Tag=0x0, Call Id=153,
*Jul 17 07:33:49.133: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 17 07:33:49.133: :cc_free_feature_vsa freeing 22F814D8
*Jul 17 07:33:49.133: vsacount in free is 0
*Jul 17 07:33:49.133: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x01
Cause i = 0x80E4 - Invalid information element contents
*Jul 17 07:33:49.173: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81
*Jul 17 07:34:38.497: //-1/968D4E000000/CCAPI/cc_api_display_ie_subfields:
cisco-username=2010
cisco-ani=2010
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=008078964848
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jul 17 07:34:38.497: //-1/968D4E000000/CCAPI/cc_api_call_setup_ind_common:
Called Number=008078964848(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=155
*Jul 17 07:34:38.497: //-1/968D4E000000/CCAPI/ccCheckClipClir:
*Jul 17 07:34:38.497: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 17 07:34:38.497: :cc_get_feature_vsa malloc success
*Jul 17 07:34:38.497: cc_get_feature_vsa count is 1
*Jul 17 07:34:38.497: :FEATURE_VSA attributes are: feature_name:0,feature_time:586683616,feature_id:23
*Jul 17 07:34:38.497: //155/968D4E000000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=008078964848(TON=Unknown, NPI=Unknown))
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/cc_process_call_setup_ind:
Event=0x3EF29CD0
*Jul 17 07:34:38.501: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 008078964848
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccCallSetContext:
Context=0x39F34E04
>>>>CCAPI handed cid 155 with tag 2 to app "_ManagedAppProcess_Default"
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccCallProceeding:
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=1, Params=0x39F3640C, Progress Indication=NULL(0)
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccCheckClipClir:
Destination Pattern=0T, Called Number=008078964848, Digit Strip=TRUE
Guid=968D4E00-0001-0000-0000-00040A01A8C0, Outgoing Dial-peer=1
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=2010
cisco-ani=2010
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=008078964848
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccIFCallSetupRequestPrivate:
Called Number=008078964848(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
*Jul 17 07:34:38.501: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 17 07:34:38.501: :cc_get_feature_vsa malloc success
*Jul 17 07:34:38.501: cc_get_feature_vsa count is 2
*Jul 17 07:34:38.501: :FEATURE_VSA attributes are: feature_name:0,feature_time:586683840,feature_id:24
*Jul 17 07:34:38.501: //156/968D4E000000/CCAPI/ccIFCallSetupRequestPrivate:
*Jul 17 07:34:38.501: //156/968D4E000000/CCAPI/ccCallSetContext:
Context=0x39F363BC
*Jul 17 07:34:38.501: //155/968D4E000000/CCAPI/ccSaveDialpeerTag:
*Jul 17 07:34:38.505: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x9 is 0x0 0x0, Calling num 2010
*Jul 17 07:34:38.505: ISDN BR0/1/0 Q931: Sending SETUP callref = 0x0002 callID = 0x8004 switch = ntt interface = User
*Jul 17 07:34:38.509: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x02
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '008078964848'
*Jul 17 07:34:38.661: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x82
Channel ID i = 0x89
Exclusive, B1
*Jul 17 07:34:38.661: //156/968D4E000000/CCAPI/cc_api_call_proceeding:
*Jul 17 07:34:38.713: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x82
*Jul 17 07:34:38.713: //156/968D4E000000/CCAPI/cc_api_call_disc_prog_ind:
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/ccCallDiscProgInd:
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x9B, gcid=CDE8E24D-C73611EA-80DDFDA0-7C21A54E, tag=0x0)
*Jul 17 07:34:38.713: //156/968D4E000000/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x9C, gcid=CDE8E24D-C73611EA-80DDFDA0-7C21A54E, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=155, Call Id2=156, Tag=0x0
*Jul 17 07:34:38.713: //155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:34:38.713: cc_api_get_xcode_stream : 4983
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/cc_api_bridge_done:
Conference Id=0x2, Source Interface=0x3EC95ACC, Source Call Id=155,
Destination Call Id=156, Disposition=0x0, Tag=0x0
*Jul 17 07:34:38.713: //156/968D4E000000/CCAPI/cc_api_bridge_done:
Conference Id=0x2, Source Interface=0x3F44FECC, Source Call Id=156,
Destination Call Id=155, Disposition=0x0, Tag=0xFFFFFFFF
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x2, Destination Call Id=156)
Call Entry(Conference Id=0x2, Destination Call Id=155)
*Jul 17 07:34:38.713: confID:0x2; callEntry1 callID1:0x9B, type:3; callEntry2 callID2:0x9C, type:6
*Jul 17 07:34:38.713: //156/968D4E000000/CCAPI/cc_api_caps_ind:
*Jul 17 07:34:38.713: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
*Jul 17 07:34:38.713: sprt_latency 200, sprt_retries 12
Destination Interface=0x3EC95ACC, Destination Call Id=155, Source Call Id=156,
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/cc_api_caps_ind:
*Jul 17 07:34:38.713: voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voice_sprt_payload 120
Destination Interface=0x3F44FECC, Destination Call Id=156, Source Call Id=155,
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=3755)
*Jul 17 07:34:38.713: //156/968D4E000000/CCAPI/cc_api_caps_ack:
*Jul 17 07:34:38.713: //155/968D4E000000/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=155
*Jul 17 07:34:38.717: //155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:34:38.717: cc_api_get_xcode_stream : 4983
*Jul 17 07:34:38.717: //155/968D4E000000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2, Call Id1=155, Call Id2=156
*Jul 17 07:34:38.717: //156/968D4E000000/CCAPI/cc_api_voice_mode_event:
Call Id=156
Call Entry(Context=0x39F363BC)
*Jul 17 07:35:06.325: //155/968D4E000000/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x3EC95ACC, Call Id=155
*Jul 17 07:35:06.325: //155/968D4E000000/CCAPI/ccConferenceDestroy:
Conference Id=0x2, Tag=0x0
*Jul 17 07:35:06.325: confID:0x2; callEntry1 callID1:0x9B, type:3; callEntry2 callID2:0x9C, type:6
*Jul 17 07:35:06.325: //155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:35:06.325: cc_api_get_xcode_stream : 4983
*Jul 17 07:35:06.325: //156/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jul 17 07:35:06.325: //155/968D4E000000/CCAPI/cc_api_bridge_drop_done:
*Jul 17 07:35:06.325: //156/968D4E000000/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=155, Disposition=0x0, Tag=0x0
*Jul 17 07:35:06.325: //155/968D4E000000/CCAPI/cc_generic_bridge_done:
*Jul 17 07:35:06.325: //156/968D4E000000/CCAPI/ccCallDisconnect:
*Jul 17 07:35:06.325: //156/968D4E000000/CCAPI/cc_api_get_transfer_info:
*Jul 17 07:35:06.325: //155/968D4E000000/CCAPI/ccCallDisconnect:
*Jul 17 07:35:06.337: //155/968D4E000000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EC95ACC, Tag=0x0, Call Id=155,
*Jul 17 07:35:06.337: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 17 07:35:06.337: :cc_free_feature_vsa freeing 22F814D8
*Jul 17 07:35:06.337: vsacount in free is 1
*Jul 17 07:35:06.345: //156/968D4E000000/CCAPI/cc_api_call_disc_cause_update:
Cause Value=28
*Jul 17 07:35:06.349: //156/968D4E000000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3F44FECC, Tag=0x0, Call Id=156,
*Jul 17 07:35:06.349: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 17 07:35:06.349: :cc_free_feature_vsa freeing 22F815B8
*Jul 17 07:35:06.349: vsacount in free is 0
*Jul 17 07:35:06.353: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x02
*Jul 17 07:35:06.401: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x82
From your first post, L3 is controller by CUCM so its a  MGCP gateway.
I have run some debug on isdn q931, voip ccapi inout. Basically, from my cell phone, I can always reached 0334575243 but this DDI should translate to IP phone ext 2010. So, the IP phone never get the ringtone. You need to do translation.
Channel ID i = 0x89
Exclusive, B1
Cause i = 0x829C - Invalid number format (incomplete number) >>>>> are you dialing correct number or does ISP expecting more informations from you to process the call ??
James Liao
My translation rules are simple.
rule 1 /^34575243/ /2010/
voice translation-rule 2
rule 1 /^2010/ /0334575243/
Here are my dial peer and dial pots configure for your ref:
dial-peer voice 2 voip
destination-pattern 03345752..
session transport udp
incoming called-number 0T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
destination-pattern 0T
incoming called-number 03345752..
codec g711ulaw
no vad
direct-inward-dial
port 0/1/0
forward-digits all
Cause i = 0x829C - Invalid number format (incomplete number) >>>>> are you dialing correct number or does ISP expecting more informations from you to process the call ?? >>> Yes, I am calling my local cell phone. I got the ringtone from IP phone, but it never reach my cell phone...
You need to check with ISP, why they Disconnected the call with cause Invalid number format (incomplete number).
 I have seen some ISP expecting type informations to process the call.
can you share the show ISDN status.
James Liao
Nothing wrong with ISP. I fixed the issue anyway.
It's the dial-peer and TP.
Thank you for your advise!
